- Nj
It's a balance charger, you plug the balance port in only. I have a similar charger and just the balance leads get plugged in. Your charger can do 1-3s so 3s would be the plug to the left.
Yes, thats why I asked, what new battery I will need, so it fits in stock Losi tray and could be charged via this Dynamite charger. How is your LiPos powering the trucks? What plug do you plug where? On my DBXLE I use the XT90 to the ESC and the ESC is pluged via 3pin black connector to the receiver on the esc slot. I ask so many questions, because I will get the car on eastern, so everything will be closed. I can't go and by missing stuff. I try to order everything I will need in advance.Just curious, you know you can't use those in the 5ive t right?
I have DX5Pro from the DBXLEYou might need a control
Looks like you pretty much got it covered
Sorry, missed that post of yours. Yes if 2S, balanced plug is 3 pins, 3S will have 4pins. I was thinking like mine other charger- you need to plug balanced cable and the charging cable.10x Rep. Now I just need to find a Lipo, which will fit in the tray. Got the stock dimensions of it? I checked the DDM battery with 101/45/28, but maybe the tray can be much the same or also quite biger/taller.It's a balance charger, you plug the balance port in only. I have a similar charger and just the balance leads get plugged in. Your charger can do 1-3s so 3s would be the plug to the left.
What about putting 2 in front and leave stock tyres at the bag so you can skid? Anyway, order is on the way, so will see how it goes. I can put them on the DBXLE and get the Ultra Grip from it and put on 5T...That's a big no to the quick connect fuel lines, other members had an issue with them leaking or introducing air into the lines. I have the super hogs on my big bore 5ive t and I made the mistake of locking the rear diff, if you lock the diff and turn to fast you'll cause it to roll over those tires have tons of grip. I'd reconsider your choice on tires if you plan to be aggressive you are and fast you want to turn.
Wow smoking you really did a good job of destroying the 1/8 nitro car
Sadly I can't find the pics from mine DBXLE reck. I hit a curb at 60mph only with the fron right tire. The whole car just desintegrated. ESC shot out in one directions front diff in other, motor mount twisted from the impact. Chassis was almost 2in bent out of shape....It was carnage. Spent almost an hour searching for all the scattered parts (it was near a park with trees and grass)...I ran quick connects on RC plane and nothing but a pain in the a$$.
Don't add anything it doesn't need in the system you are asking for trouble. Leaks and also anything you put in line could easily be a restriction for fuel flow.
The last thing you want is for it to go into a lean condition.
Let me take that back.
Actually, the last thing you want is to smash head on into a wall at wide open throttle. LOL
Like this View attachment 91695View attachment 91696
