OK. Got some answers, bur some questions remained. Someone willing to elaborate on those?1. Kill Switch- https://rc-car-online.de/en/product...itch-and-status-led-for-all-transmitters.html
3. Since I own DBXLE on 8S, maybe the 5T will lack of power. So should I go for the 34cc esp mode, or go for some 40cc complete engine? If I buy now a pipe for 32, will it fit to the 40 or will I need bigger one?
6. Maybe some other than stock tires: https://rc-car-online.de/en/product...-x60-tires-for-hpi-losi-24-mm-hex-drive-.html
7. Diff oils- most are runing 500k-1m-500k. In the manual stock is 10-15-5. Is it realy such a huge difference or are there different scales to measure?
8. Shock oil and rear springs. I am with hardest springs on my DBXLE and when I jump (not more than feet) I almost always belly land. And the 5T should be also heavier. So are orange ok, or should I go for red. I have those options: https://rc-car-online.de/en/product...osi-5ive-t-2-0-mini-and-ufrc-growler-gx1.html. No orange, and red is second. Should I go for black?
10. Steering servo- I think I will first run stock one, since I was ok with stock Spektrum on my DBXLE and I don't race. Will see how it goes. But when I decide to upgrade- should I go for the push pull or not?
11. Clutch, bell thingy. Here it is a dark matter for me. No clue, what is ok, what to search, what to buy and why.
12. I saw on youtube a supercharger for zenoah motors. Are you familiar with it? Is it any good?
10x Rep!For you to have comparable power to an 8s+ electric rig you'll l need a big bore engine to be remotely competitive. Gas is just different and it's the powerband and the noise that electric lacks. If you want a big bore anticipate spending roughly 3-4k at bare minimum said and done.
So for your list.
#3. Run the truck first so you see what stock looks like so when you build/buy a bigger engine you'll see the difference.
#6. The stock tires are fine and do last, if you read what I've said prior as long as you stay off pavement they last awhile.
#7. 500k-1m-500k is for big bores, you'll never be able to turn properly with 500k diff oil in the front. Big bores are point and shoot and slowly turn around. Run 100-125k front, lock the center so it evenly distributes power front and rear.
#8. 50wt shock oil and TLR orange springs, since orange is not available you want 13.9lb or 14.2 lb rate springs front and 11.0lb rate rear.
#10. The dbxl isn't remotely comparable to the 5ive t and the steering servo that comes with the 5ive does just fine for bashing.
#11. Leave the clutch bell alone, it has no faults like the kraken vekta.5 does. If you want a forever clutch get the FS steel clutch with an 8k spring. In any case fiber or steel clutch you should be using an 8k rpm engagement spring anyway. The truck will feel more zippy off the line with just that mod alone.
#12. The supercharger is a gimmick and that's it,there's nothing else to say about that.
A 40cc pipe will only fit 40cc and up depending on who you buy it from. A 40cc rovan pipe will fit that engine only and could not be used on a 46cc taylor engine,they use different ports and flanges. I would suggest only dealing with zenoah engines or Taylor/alx. Your asking for problems with a rovan engine, may not be immediate but you'll encounter issues later on.
As for a pipe and it's performance, vrc,olimat, bartolone is it and any off brand Chinese pipe is just a noise maker.
