- Montreal
Hi guys, super stoked for my first big block. Wasn't sure on the best platform to run it on, so I decided a vesla was what I'd try out.
Love the way the Taylor big blocks flop a big car around like a rag doll, so I wanted to try 2wd instead of 4 and my baja would need to be extensively modified to handle it, so I kept it the way it is for now.
Started with the big block roller from Taylor as it comes with the mount to fit the big block and the layshaft also pre-installed.
Got the Taylor transmission housing to hold the power, but if anybody used this car with the gears as dry as these were no engine what have pushed for long. That's why most guys tear down a new rtr to check.
Got the housing installed back on no problem but the blackbone gears 25/51, I got from Taylor as per his suggestion don't have any backlash and worse bind terribly in about the same spot as the large gear makes a full turn, the rest of the turn it does roll freely.
Is there an indexing for the blackbone spur to holder? Pinion gear had two shims on it and I putbthem between Pinion and plate.
Any suggestions or experiences with this?
