John Parks
Print my own
Got it today! I do say it seems better built with the small but necessary upgrades. Installed the 2" wheelbase extwnsion kit, and also 1" axle extenders.
Shock shafts are much larger, and they also upgraded the bottom spring perch to alloy as the plastic ones were junk. I popped open the axles and installed the brass bushings between the pinion bearings, also checked diffs and all were good with fluid and loctite on the screws. So far pretty impressed.
