Tips for Installing the Full Force RC High Flow Fuel Kit
Z.hb71
Build Thread Contributor
Heres my tips for installing the Full Force RC High Flow Fuel Kit.
first one: to get the breather into/on the tygon fuel line that is included with the kit, make sure to heat up the line with a blow dryer, you can use a heat gun but don't hold it on the line for too long as you might burn or melt the fuel line.
Second one: Use lube, lots of it, i used 3&1 oil for my lube. the combination of lube and heating the line makes it slip on real easy. Lubbbbeeee is gooooooddd :p:ROFLMAO:
THird: when installing the fuel line clamps, use lube as well, so it slips and slides on the fuel line for easier install.
if you would like to add another tip, please do so!
