Sportsline 4wd with a 30.5 engine
Fasmax
Long Island
Curious if anyone else has put a 30.5 in a 530.I did and had to remove my aluminum small engine mount and grind down the plastic mount to fit the bigger motor.Feels and looks solid but we’ll see when I run it.Removed a lot of material.Thinking about doing the same with the aluminum mount and use the plastic as a template.
Brother your life saver just bought fg and I have a $800 OBR just sitting might be a bit much 34cc signature series.. gonna need taller gears I bet
what type of pipe you have mounted?
