Redcat rampage wheels
Kmak
Hello, can anyone tell me where I can find a set of wheels for the redcat rampage xb, gas. I have been searching online but can't seem to find any.
I have the ramtech 24mm adapters on mine but they are getting hard to find. Ebay possibly. I use the xr cva's in the front with hub pin and mt cva's in the rear. X series has 10mm axles and mt's are 12mm like most 1/5 scale rc.
Well done mate.
I've found that if you have the part number you can also find parts under the HSP brand.
HSP are the manufacturers and build to order for Redcat and a couple of others whose names escape me this early in the morning.
2am here.
Yep the 10mm axles make life difficult.
The MT,TT and Dunerunner all have 12mm and you don't need adapters.
KM and Rovan hexes fit straight on and are about $4 each.
Ok......so I have tried all that you guys had suggested, including the websites to buy them from, but those websites don't actually have them in stock. I think my best hope is to get an adapter to increase my wheel options. Anybody has any suggestions on where to get or make one?
Depending on where you live you could find a machine shop with a cnc and ask them to make some... pretty standard request honestly you just give them one currently on the truck so they have your axle and pin diameter and tell them you want a 24mm hex instead of the square.
Thanks for the replies, I have been trying the suggestions being made, but not with much success. I looked at the MT as @Phill2 had suggested, but not sure how that would work. I would prefer not going down the machine shop option unless I have to. @RcJunkie13 can you explain how the arrma kraton hexes work, I looked at the images, but the ones I saw doesn't look like they fit even if I mod them.
I called Redcat and they basically said they can't help me because they discontinued the part/vehicle. I wouldn't mind if someone good walk me through modding so sting so I can have more wheel options to pick from. I would really, really appreciate it.
I feel like dead on giving up on this, I have been searching everywhere for some suggestions but it seem as if the Rampage XB is dead in the RC world. Redcat failed me man, they just gave up on supporting car.
@RcJunkie13 ok thank you, could you say which one I should buy? I see a few options I am trying to avoid getting the wrong ones, which wheel(s) option should I be looking at when I get these? Please.
If you can measure your axles accurately there may be some hope. I had a redcat rampage xt and i too was searching for adapters...I fixed the issue by selling it while it was still in running condition
