- Queens
Or U can just try a new plug
True but if i dnt have a new plug handy and i want to rule out the coil as well I would like to have a spark plug tester as wellOr U can just try a new plug
Yeah that's a crappy one like I have at home, they work but not the best.
Open mouth insert foot. You have no way to test the ignition system properly without a tester. Hey my pug fires when there isn't compressed fuel/air around it, everything just be good. Fair amount of assumption going on here.Or U can just try a new plug
thats not what I meant , instead of using the tester to see if you are getting spark from the coil or not you can test a new plug, it does the same jobOpen mouth insert foot. You have no way to test the ignition system properly without a tester. Hey my pug fires when there isn't compressed fuel/air around it, everything just be good. Fair amount of assumption going on here.
i vote ZWho wants to be the first person to use their tounge as a spark tester?
who says it has not been doneWho wants to be the first person to use their tounge as a spark tester?
