- Nj
Just curious what's the UL-19 made out of..is it abs or fiberglass? If it's abs I'd be worried about the stress on the hull
That's possible. Are you using the little cheap supplied wrenches or getting on that with some real tools?Hello learning curve are you in there ?? Right side shaft keeps coming loose , is there a cause of this ? I put those cable savers on could that be the problem ?
