MCD W5 max ultimate build
Got em. They are light. Less spikes than brp super spikes. Diameter is slightly less than brp super spikes. But the compound is way harder than brp. Waiting on rims.
All decaled. I mounted the body to the cage using Losi mounting hardware with the mcd phillips screws. The support from the Losi hardware is way better. 81183F6E-BA03-492E-9CA7-B73E33C057F7.jpeg56DEACB5-0DCF-42F0-BB24-C5C745719459.jpeg6CB10C25-AEBC-426E-87D5-AF9DD9B65FE0.jpegC8817D0F-C6D1-494A-B89E-F0A002EDF789.jpegC29E5387-D005-4F40-9264-A2D20B156AA2.jpeg17D931F6-0B1A-41C9-984F-DDE9A0394FDE.jpeg619D7791-9D5E-461B-AC67-BDDCA9949FB2.jpeg8BD4738A-9587-4845-A9CE-8A68FDB7CD2B.jpegBE6468B6-72E5-45BE-9C06-E44917C51002.jpeg
Well it was a battle! But it’s done! Going to see if they will hold together! This was the toughest set of bead locks I have ever put together!
A marriage of DDM spoke and ALX Spike. Along with some DDM aluminum outer rings. The tires are made from a very hard rubber with a hard foam insert. 47DF2215-3C36-4762-A1B6-B2FCDAB76D3F.jpeg84170A99-72F8-459F-A1D7-32F3C8BCCF32.jpeg7AED67A6-4DB0-436D-8A77-4826F506473D.jpegD83F8DCF-6BCE-4C7B-87B8-60C512C5C0F6.jpegA1BB33A9-5592-4FBC-95EB-D42497E49A71.jpeg
