mcd competition v4 monster truck
Draggline53
macomb mi
I guys I'm to buy the mcd competition v4 monster truck. Just wondering can anyone give me some info about this truck! What to look for, what should be upgraded frist gears, bearings, suspension? look forward to hearing from you soon
Guys I'm going to purchase my mcd competition v4 monster truck next next from largescalerc. Can't wait it's going to be awesome!
largescale our out where do i purchase one at germany? What about the gears change to the steel ones. And what gear ratio should I have it set at HI or LO for speed and torgue? Thanks a lot.
Again where should I start my up grades from: 1 alloy engine carrier 2 transmission gears 3 Diff and diff gears 3 alloy suspension? Tell me what you think?
modelismo is the place to get MCD parts from and Oliver ships very fast:)
http://www.rc-modelismo.com/Engine-Carrier-Plate-billed-Alloy-Cnc-Mach-Option
your transmission gears are already steel,so no upgrade needed
shocks should be ok,some upgrade to 8mm shafts:D
as for diffs leave well alone untill they break:w00t:
then if the bank allows,the LSD diffs are bullet proof:cool:
http://www.rc-modelismo.com/Front-LSD-Diff-Assy-With-Bearing-optional
http://www.rc-modelismo.com/Rear-LSD-Diff-Assy-With-Bearing-optional
there are also alloy diff cases available now,this eliminates the plastic
diff cases breaking around the front bearing,the later ones having a
larger bearing;) these are on the modelismo web page.......
i do own Olivers evo 3 Ultimate,which is all alloy with the LSD's and alloy
lower diff cases fitted
K....
terbor are this diff cases for both the upper and lower. i'm new at this
Oliver has 2 types,the alloy top and bottom type are i think for
the small front bearing diffs......these are not made by MCD but not
MCD prices :lol::lol:
the other looks like it is the MCD large bearing one,
but only the bottom half is alloy :rolleyes: and MCD prices :w00t:
you will have to contact Oliver at Modelismo to confirm availability
and fit........
K....
you will have to get your skates on for the alloy gear carrier :)
they are now showing in short supply,maybe last one
don't be tempted with any other aftermarket makes,as there are
non better than the MCD ones :D
full sets of front and rear alloy arms at Modelismo,now at bargain prices:cool:
K....
