Losi Desert Buggy XL (DBXL) Manual and Parts Listing
Status
Not open for further replies.
WoodiE
Kind of good admin.
Community Leader
Kentucky
Losi Desert Buggy XL Manual
(model #:LOS05001)
Losi DBXL Member Gallery: Show us your DBXL's
Losi DBXL Parts Listing
#DYN1460 - 6V 1700mAh Ni-MH Receiver Pack, 5C Flat
#LOS250006 - Body Panels, Silkscreened
#LOS251007 - Roll Cage
#LOS251008 - Light Bar, FR/RR, Body Post
#LOS251009 - DBXL Chassis
#LOS251010 - Chassis Side Guards & Chassis Braces
#LOS251011 - Front/Rear Bumper & Bumper Brace
#LOS251012 - Radio Tray & Gas Tank Mount
#LOS251013 - Steering Rack Set & Toplate
#LOS251014 - Steering Drag Link
#LOS251015 - Steering Post/Tube/Spring Set
#LOS251016 - Front/Rear, Bulkhead Set
#LOS251017 - Radio Tray Linkage Set
#LOS251018 - Gas Tank Complete
#LOS251019 - Gas Cap
#LOS251020 - ST & TH Servo Horn: S901 Servo
#LOS251021 - Mount/Guard, Engine, Set
#LOS251022 - CtrDiff/DrivetrnMnt&Gear Cover:
#LOS251023 - Center Differential, Assembled
#LOS251024 - Brake Pads/Springs/Cam/Discs
#LOS252001 - Driveshaft & Axle Dogbone (2)
#LOS252002 - Center Dog Bone, Short (1)
#LOS252004 - Front/Rear Diff Set,Assembled:
#LOS252005 - Front & Rear Gear Box
#LOS252006 - Front/Rear Diff Outdrive Set
#LOS252007 - Center Differential Outdrive Set
#LOS252008 - Front/Rear 43T Ring & 13T Pinion Set
#LOS252009 - Differential Rebuild Kit (1)
#LOS252010 - Front/Rear Differential Case (2)
#LOS252011 - Front/Rear Stub Axle (2)
#LOS252012 - Front/Rear Wheel Hex & Pin (2)
#LOS252013 - Wheel Nuts, Serrated (4)
#LOS252014 - Clutch Bell
#LOS252015 - 61T Spur Gear
#LOS252016 - 20T Pinion Gear
#LOS252017 - Axle Boot Set (10)
#LOS252018 - Front Universal (1)
#LOS252019 - Front Center Driveshaft (1)
#LOS252020 - Universal Rebuild Kit (2)
#LOS252021 - Rear Center Driveshaft (1)
#LOS253002 - Front, Shock, Complete (2)
#LOS253003 - Rear, Shock, Complete (2)
#LOS253004 - Fr/Rr Shock Body, Cap, Aluminum (2)
#LOS253005 - Fr/Rr Shock Shaft & Piston Set
#LOS253006 - Spring Cups/Clips/Shock Ends (2)
#LOS253007 - Shk Rebuild Kit/O-Rings/Spacers(2):
#LOS253008 - Shock Boot Set (4)
#LOS253009 - Shock Adjuster Nut w/O-Ring, Alum
#LOS254005 - Spindle Carriers/Spindles/Hubs
#LOS254006 - Suspension Arm Set (4)
#LOS254007 - Front Hinge Pin Brace, (1)
#LOS254008 - Rear Hinge Pin Brace, (2)
#LOS254009 - Hinge Pin Brace Inserts, Set
#LOS254010 - Hinge Pin, Set
#LOS254011 - Turnbuckles, Set
#LOS254012 - Front/Rear Shocktower Set
#LOS254013 - Front & Rear Sway Bar Kit
#LOS255000 - Set Screw, Set,(20)
#LOS255001 - Cap Head Screw, Set, (30)
#LOS255002 - Button Head Screw, Set, (40)
#LOS255003 - Flat Head Screw, Set, (30)
#LOS255004 - Screw, 5x16mm, Engine Mount, (8)
#LOS255005 - Screw, 3x10mm (10)
#LOS256000 - Locknut, Set, (15)
#LOS256001 - Washer/Shim, Set, (20)
#LOS256002 - EngMount Spacer & Clutch Mount, Aluminium
#LOS256003 - Flanged Bushing, Steel, Set (11)
#LOS256004 - Ball, Shock/Link (10)
#LOS256005 - Body Clip, Large (10) & Small (4)
#LOS257000 - Bearing, 8x19x6mm, (4)
#LOS257001 - Bearing, 10x22x6mm, (4)
#LOS257002 - Bushing, 10x7x4mm, (4)
#LOS45004 - Left & Right Tire (1ea), Pre-mounted
#LOS45005 - Wheel/Beadlock, Black (2)
#LOS45006 - Left & Right Tire (1ea) & Foam Insert(2)
#LOS55003 - Air Cleaner Set
#LOS55004 - AirCleaner Foam Elements,Pre-Oiled(4)
#LOSB5039 - Clutch Shoes & Spring, 8,000 RPM
#LOSR5001 - 26cc Hi-Performance Engine
#LOSR5010 - Pull-Start Assembly, Losi 26cc
#SPM2322 - DX2E 2-Channel DSMR Surface Radio System
#SPMS901 - S901 30kg Servo
#SPMSR410 - SR410 4-Channel DSMR Sport Surface Receiver
Losi Desert Buggy XL Video
Status
