Losi 5ive-T Manual & Parts Listing
Status
Not open for further replies.
WoodiE
Kind of good admin.
Community Leader
Kentucky
Losi 5ive-T 4WD Manual
BULLETIN: It has come to our attention that a small quantity of the 5IVE-T trucks were assembled with a shorter than correct length screw to attach the front gear box/skid plate. Before operating your 5IVE-T please remove and check the two front most 6mm flathead screws from the bottom of the chassis and confirm they are ¾”/20mm long. If they are not please call Losi Service @ (909) 390-9595 Ext. 300 and you will be sent the longer screws. Under no circumstances should you operate the 5IVE-T with the shorter screws. We apologize for this error and thank you for your help correcting it.
Losi 5ive-T Parts Listing
#DYN1444 - Speedpack 6V 3000mAh NiMh 5C Flat Receiver Pack
#LOSA99209 - HD Ring & Pinion Grease (10ml)
#LOSB0884 - S900S 1/5 Scale Steering Servo w/Metal Gears
#LOSB0885 - S900T 1/5 Scale Throttle Servo with BB
#LOSB0897 - HD On/Off Switch w/20AWG Wre&Gld PlatedPlugs
#LOSB2071 - Front Suspension Arm Set (2)
#LOSB2072 - Front Spindle Set (2)
#LOSB2073 - Front Spindle Carrier Set (2)
#LOSB2074 - Front King Pins & Arm Bushings, Alum.
#LOSB2076 - Rear Suspension Arm Set (2)
#LOSB2077 - Rear Hub Carrier Set (2)
#LOSB2078F - Front Hinge Pin Brace Set, Alum: (2)
#LOSB2078R - Rear Hinge Pin Brace Set, Alum (2)
#LOSB2079 - F/R Pin Mount Covers (4)
#LOSB2080 - Hinge Pin Set (6)
#LOSB2082 - Front Shock Tower
#LOSB2084 - Rear Shock Tower
#LOSB2540 - Main Chassis Plate
#LOSB2541 - Front Transmission Case Set
#LOSB2542 - Rear Transmission Case Set
#LOSB2543 - Bearing Inserts, Rear Diff/Trans
#LOSB2545 - Center Diff Mount Set
#LOSB2550 - Servo Saver & Bellcrank Plastics (3)
#LOSB2551 - Steering Post Set (2)
#LOSB2552 - Steering Drag Link & Hardware
#LOSB2553 - Servo Saver Tube, Spring & Adjuster
#LOSB2558 - F&R Chassis Brace & Spacer Set
#LOSB2562 - Sway Bar Set & Hardware (3 ea. F&R)
#LOSB2570 - Side Guard Set (2)
#LOSB2571 - Left Cage Side
#LOSB2572 - Right Cage Side
#LOSB2573 - F&R Bumper Set
#LOSB2574 - Front Skid Plate,Bumper Brace & Spacers
#LOSB2575 - Headlight Set
#LOSB2576 - Rear Bumper Brace Set (3)
#LOSB2577 - Front Cage Support Set (2)
#LOSB2578 - Center & Front Top Cage Support Set
#LOSB2579 - Rear Top & Side Cage Set
#LOSB2580 - Rear Cage Mount & Fender Brace Set (4)
#LOSB2581 - Mud Flap & Retainer Set (2)
#LOSB2582 - Body Mount Washers & Pads (56)
#LOSB2585 - Radio Tray Set
#LOSB2586 - Radio Tray Covers
#LOSB2851 - Front Shock Shaft (1)
#LOSB2852 - Rear Shock Shaft (1)
#LOSB2853 - Front Shock Body & Adjuster (1)
#LOSB2854 - Rear Shock Body & Adjuster (1)
#LOSB2855 - Shock Plastics & Balls (4)
#LOSB2856 - Shock Rebuild/Hardware Set (4)
#LOSB2857 - Shock Boots (8)
#LOSB2858 - Shock Caps, Blue (2)
#LOSB2859 - Shock Mount Set (4)
#LOSB2965 - Front Springs 11.6lb Rate, Blue (2)
#LOSB2972 - Rear Springs 9.3lb Rate,Red (2)
#LOSB3201 - Diff Housing Set (1)
#LOSB3202 - Internal Diff Gears & Shims (6)
#LOSB3203 - Diff Seal & Hardware Set (1)
#LOSB3204 - Front Diff Ring Gear
#LOSB3206 - Rear Diff Ring Gear
#LOSB3208 - F/R Diff Pinion Gear, 13T
#LOSB3210 - Center Diff Spur Gear, 58T
#LOSB3212 - F/R Diff Outdrive Set (2)
#LOSB3214 - Center Diff Outdrive Set (2)
#LOSB3216 - F/R Driveshaft & CV Coupler (1)
#LOSB3217 - CV Joints & Pins (2)
#LOSB3218 - Front Center Driveshaft & CV Coupler
#LOSB3219 - Rear Center Driveshaft & CV Coupler
#LOSB3220 - F/R Center Drive Pinion Coupler Set (2)
#LOSB3224 - F/R Stub Axle & Pins (1)
#LOSB3225 - F/R Wheel Hex & Pin (2)
#LOSB3227 - Wheel Nuts, Blue Anodized (4)
#LOSB3230 - Brake Cams & Bushings (2)
#LOSB3231 - Brake Disk, Pad & Screw Set
#LOSB4610 - Wheel,Shock & Multi-Wrench Set
#LOSB5014 - Gas Tank Mount Set
#LOSB5015 - Gas Tank Complete
#LOSB5016 - Gas Tank Cap Set
#LOSB5017 - Gas Line & Clamp Set
#LOSB5022 - Air Cleaner Set Complete
#LOSB5023 - Air Cleaner Foam Elements (2ea)
#LOSB5023 - Clutch Mount w/bearings & Hard. (Assm)
#LOSB5038 - Clutch Bell & Hardware
#LOSB5039 - Clutch Shoes & Spring, 8,000 RPM
#LOSB5044 - 19T Pinion Gear, 1.5M & Hardware
#LOSB5800 - Spring Clip Set (14)
#LOSB5801 - Engine Mount Inserts & Screws, 19T (4)
#LOSB5900 - Steering Linkage Set
#LOSB5901 - Throttle/Brake Linkage Set
#LOSB5902 - Turnbuckle Set (6)
#LOSB5903 - Rod End Set (12)
#LOSB5904 - Camber & Steering Pivot Ball Set (12)
#LOSB5970 - Steering Bearing Set, 10x15x4mm (4)
#LOSB5971 - Inner Axle bearings, 20x32x7mm (2)
#LOSB5972 - Outer Axle Bearings, 12x24x6mm (2)
#LOSB5973 - Diff Support Bearings, 15x24x5mm,Flanged(2)
#LOSB5974 - Diff Pinion Bearings, 9x20x6mm (2)
#LOSB5975 - Clutch Bell Bearings, 15x28x7mm (2)
#LOSB6085 - 4mm BH Screw Asst. (27)
#LOSB6110 - 5mm BH Screw Asst (24)
#LOSB6450 - Wheel Screw Set, 3x10mm BH & Cap (20ea)
#LOSB6451 - 3mm BH & Cap Screw Asst (38)
#LOSB6465 - 4mm FH & Cap Screw Asst. (32)
#LOSB6480 - 5mm FH & Cap Screw Asst. (24)
#LOSB6481 - Rear Toe Block & Brace Screws
#LOSB6490 - 6mm BH & FH Screw Asst (20)
#LOSB6501 - Set Screw Asst. 3,4,5 & 8MM (19)
#LOSB6535 - Washer Assortment, 5 sizes (25)
#LOSB6560 - Drive Pin Set (14)
#LOSB6579 - Lower Shock Mounting Screw Set, 5mm (6)
#LOSB6590 - Lock Nut Asst. 3,4,5,6MM (24)
#LOSB6591 - Side Cage Nut-Inserts
#LOSB6592 - Emergency Hardware Kit
#LOSB7027 - Wheel and Beadlock Set (2)
#LOSB7028 - Beadlock Set, Inner & Outer Black (2)
#LOSB7240 - Nomad Tire Set, Firm (1ea. L/R)
#LOSB7241 - Tire Inserts, Soft (2)
#LOSB8101 - Hood/Front Fenders Body Section
#LOSB8102 - Cab Body Section
#LOSB8103 - Body Left Fender & # Plate
#LOSB8104 - Body Right Fender & # Plate
#LOSB8255 - 5IVE-T Sticker&Graphic Sheet Set: Black
#LOSB8256 - 5IVE-T Sticker & Graphic Sheet Set: White
#LOSR5001 - 26cc Hi-Performance Engine
#LOSR5010 - Pull-Start Assembly, Losi 26cc
#LOSR5012 - Piston & Ring Set, Losi 26cc
#LOSR5013 - Piston Ring Only, Losi 26cc
#LOSR5015 - Flywheel, Losi 26cc
#LOSR5016 - Ignition Coil & Screws, Losi 26cc
#LOSR5017 - Spark Plug, Losi 26cc
#LOSR5018 - Kill switch, Losi 26cc
#LOSR5025 - Hardware Set, Losi 26cc
#LOSR5026 - Muffler Screws, Losi 26cc
#LOSR5030 - Cylinder Gasket, Losi 26cc
#LOSR5031 - Exhaust Gasket(2), Los 26cc
#LOSR5033 - CarbMntingGasket Set(2), Losi26cc
#SPM1452 - RPM Sensor
#SPM1454 - Head Temperature Sensor-Long Lead
#SPMA3003 - Heavy-Duty Servo Extension 12"
#SPMSR3300T - SR3300T DSM 3-Ch Rx w/Telemetry: Surface
Losi 5T Video
Losi 5ive-T First Run Basics
Losi 5ive T Post Run Maintenance
Status
