Its coming along but......
NW ohio
I got all the parts for the slipper clutch but it an odd design. Instead of a spring it has wavy washers and a thrust bearing. Does this bearing need lubrication. I wish I could find a build manual. All I have is schematics.It's part number 6069.
It's a Belleville spring, it's just shaped similar to a washer. Very predictable spring rate in a small package. Use them on huge hydraulic brakes as the e brake/park brake mechanism. The thrust bearing should be very lightly lubricated, you don't want any lube getting on the clutch material.
