HPI Baja 5B Manual and Parts List
Status
Not open for further replies.
WoodiE
Kind of good admin.
Community Leader
Kentucky
HPI Baja 5B RTR Manual
(model #:110190)
HPI Baja Member Gallery: Baja 5B Picture Gallery!!!
HPI Baja 5B Parts Listing
Chassis Components
#102158 - Rear Lower Brace A 6x70x4mm
#102159 - Front Upper Brace 6x60x4mm
#102160 - Rear Upper Plate (Gunmetal)
#102161 - Gear Plate (Gunmetal)
#102162 - Brake Holder Plate (Gunmetal)
#102163 - Engine Mount Brace
#102167 - Front Lower Brace 6x60x4mm
#102168 - Rear Lower Brace B 6x70x4mm
#102169 - Rear Chassis Plate (Gunmetal)
#102170 - Front Upper Plate (Gunmetal)
#102172 - Rear Brace (Gunmetal)
#102173 - Engine Mount Brace
#102214 - Joint 7x82mm (Gunmetal/2pcs)
#85404 - Radio Box Set
#85418 - Front Bulk Head Set
#85420 - Bumper Set
#85430 - Gear Box Set
#85434 - Rear Bulkhead Set
#85438 - Rear Shock Tower Set
#85439 - Roll Bar Set (Long)
#85440 - Center Roll Bar Set
#85442 - Guard Deflector Set
#85443 - Under Guard
#85445 - Gear Cover
#87430 - Roof Plate
#87477 - Main Chassis (Gunmetal)
#87551 - Rear Shock Mount Plate A
Drivetrain
#102156 - 24mm Front Hex Hub
#102157 - Wheel Hex Hub 24x27mm
#102166 - Spacer 5x12x11mm (Gunmetal)
#102171 - Brake Disk Fin Plate
#102216 - Wheel Nut 24mm
#85427 - Alloy Differential Case Set
#85428 - Spur Gear Holder
#85432 - Spur Gear 57t
#85436 - Spur Gear Mount Set
#86470 - Diff Shaft 22x48mm (2pcs)
#86478 - Diff Case Gasket (6pcs)
#86479 - Axle Boot 22x47mm (4pcs)
#86480 - Diff Gear 48tooth
#86484 - Idler Gear 30tooth
#86486 - Drive Gear 20tooth
#86488 - Drive Axle 22x68mm (2pcs)
#86601 - Brake Cam
#86610 - Heavy Duty Drive Shaft 15x120mm
#86615 - Disc Brake Hub 24x16mm
#86630 - Drive Gear Shaft 12x124mm
#86676 - Diff Screw Cap M4x6mm (2pcs)
#87424 - Brake Disk Rotor (2pcs)
#87437 - Disk Brake Shim 0.4mm (5pcs)
#87456 - Brake Pad Set
#87460 - Rubber Cap Set For Radio Box
#87474 - Diff Washer Set (For #85427
#87567 - Bevel Gear Set (For #85427
#87568 - Complete Alloy Diff Gear Set
#B075 - Flanged Metal Bushing 6x10x3mm
Suspension and Steering
#102154 - Shock Cap 20x12mm
#102155 - Shock Adjuster Nut 20mm
#102165 - Servo Saver Set (Gunmetal)
#102480 - Vvc/Hd Shock Set
#102481 - Vvc/Hd Shock Set
#75071 - O-Ring S15 (15x1
#75072 - O-Ring P20 (20x2
#75077 - O-Ring 4x1mm (Black/10pcs)
#75078 - O-Ring P10
#75079 - O-Ring S13 (13x1
#85400 - Front Suspension Arm Set
#85402 - Rear Suspension Arm Set
#85408 - Front Hub Carrier Set
#85410 - Shock Parts Set
#85413 - Shock Piston Set For Vvc/Hd
#85414 - Steering / Servo Arm Set
#85416 - Rod End Set
#85424 - Rear Hub Carrier Set
#85460 - Steering Wiper Arm Set
#85463 - Steering Tie Rod Set
#85464 - Upper Arm Ball End (A)
#85465 - Upper Arm Ball End (B)
#85467 - Steering Linkage Set
#85469 - Front Shock Mounting Set
#86401 - Turnbuckle 6x92mm
#86432 - Shock Body (20x86mm/2pcs)
#86433 - Shock Body (20x96mm/2pcs)
#86442 - Shock Boots 20x70mm (4pcs)
#86443 - Shock Boots 20x80mm (4pcs)
#86448 - Shock Shaft 6x105mm (2pcs)
#86449 - Shock Shaft 6x115mm (2pcs)
#86629 - Steering Crank Shaft 5x53mm
#86633 - Shaft 6x80mm (2pcs)
#86634 - Shaft 6x94mm (2pcs)
#86635 - Shaft 6x108mm (2pcs)
#86636 - Shaft 6x63mm (2pcs)
#86653 - Rubber Bushing 6x9x10mm (6pcs)
#86664 - Rubber Cap 6x5mm (8pcs)
#86666 - Damper Bushing (4pcs)
#86757 - Shock Spring 23x135x2.2mm
#86762 - Shock Spring Set 23x155x2.4mm
#86927 - O-Ring P6 (6x2mm/Clear/12pcs)
#87563 - Shock Repair Kit For Vvc/Hd
#87564 - Shock Repair Kit For Vvc/Hd
#87565 - Vvc/Hd Shock Bottom Cap Set
#87566 - Vvc/Hd Shock Maintenance Set
HPI Baja Engine and Engine Parts
#102164 - Spacer Set For Fuelie Engine
#102174 - Spacer Set For Clutch Bell
#107936 - Fuelie K23 Engine
#109961 - Piston Ring (1.0mm Piston
#15411 - Air Filter Set
#15448 - High Response Clutch
#15454 - Spark Plug/Cmr7h
#15460 - Carburetor (Wt-668)
#15478 - Pull Starter
#15483 - High Flow Exhaust Muffler
#85446 - Fuel Tank Set
#85462 - Throttle Linkage Set
#86490 - Clutch Bell
#86493 - Pinion Gear 17tooth
#86675 - Stop Collar 2.3mm (4pcs)
#87469 - Fuel Tank Cap
HPI Baja 5B Electronics
#102491 - Hpi Sf-20 Servo (High Torque/6
#102772 - Hpi Sfl-11mg Servo(Metal
#104058 - Hpi Tf-20e 2.4ghz Transmitter
#104060 - Hpi Rf-30 Receiver (2.4ghz
#104085 - 2.4ghz Receiver Antenna 300mm
#80582 - Receiver Switch
#87280 - Aluminum Steering Arm For Hpi
#Z149 - Antenna Pipe Set 400mm (3pcs)
Battery
#101937 - Plazma 6.0v 4300mah Ni-Mh
Hardware
#50504 - Concave Washer 5mm (8pcs)
#6163 - Servo Tape 20x100mm (10pcs)
#6203 - Body Pin
#85422 - Nut Holder Set
#86407 - Ball 6.8x16mm (4pcs)
#86411 - Ball 10x25mm (4pcs)
#86412 - Ball 10x34mm (4pcs)
#86417 - Ball 10x12mm (4pcs)
#86425 - Ball 14x17mm (4pcs)
#86607 - Flanged Collar 4x6x7mm (2pcs)
#86616 - Spacer 12x16x4mm (Purple/2pcs)
#86632 - Screw Shaft M5x3x22mm (10pcs)
#94502 - Cap Head Screw M4x6mm (10pcs)
#94506 - Cap Head Screw M4x15mm (10pcs)
#94510 - Cap Head Screw M4x25mm (10pcs)
#94512 - Cap Head Screw M4x30mm (10pcs)
#94520 - Cap Head Screw M4x50mm (6pcs)
#94529 - Flat Head Screw M4x10mm (Hex)
#94556 - Button Head Screw M4x16mm (Hex)
#94631 - Tp. Flat Head Screw M4x15mm
#94632 - Tp. Flat Head Screw M4x18mm
#94707 - Cap Head Screw M5x20mm (6pcs)
#94710 - Cap Head Screw M5x30mm (6pcs)
#94711 - Cap Head Screw M5x35mm (6pcs)
#94730 - Flat Head Screw M5x16mm (Hex)
#94732 - Flat Head Screw M5x20mm (Hex)
#94735 - Flat Head Screw M5x30mm (Hex)
#94737 - Flat Head Screw M5x40mm (Hex)
#94754 - Button Head Screw M5x12mm (Hex)
#94762 - Button Head Screw M5x40mm (Hex)
#94763 - Button Head Screw M5x45mm (Hex)
#94879 - Flat Head Screw M6x14mm (Hex)
#94909 - Button Head Screw M6x25mm (Hex)
#94910 - Button Head Screw M6x30mm (Hex)
#96501 - Pin 4x18mm (10pcs)
#96504 - Pin 4x24mm (6pcs)
#96704 - Locking Washer M4 (20pcs)
#96705 - Locking Washer M5 (20pcs)
#96706 - Locking Washer M6 (20pcs)
#96710 - Washer 8x12x0.8mm (10pcs)
#B021 - Ball Bearing 5x10x4mm (2pcs)
#B030 - Ball Bearing 10x15x4mm (2pcs)
#B089 - Ball Bearing 12x24x6mm (2pcs)
#B092 - Ball Bearing 17x30x7mm (2pcs)
#B094 - Ball Bearing 20x32x7mm (2pcs)
#Z087 - Flat Head Screw M3x20mm (Hex)
#Z103 - E Clip E-4hd (20pcs)
#Z106 - E Clip E-7hd (20pcs)
#Z216 - Button Head Screw M3x15mm (Hex)
#Z224 - Washer 3x8mm (10pcs)
#Z277 - C Clip 10.5mm (20pcs)
#Z303 - Cap Head Screw M3x42mm (6pcs)
#Z340 - Wheel Screw (Hex Socket/25pcs)
#Z362 - Button Head Screw M3x35mm (Hex)
#Z489 - Tp. Flanged Screw M2.6x10mm (Hex)
#Z562 - Tp. Flanged Screw M3x10mm (Hex)
#Z655 - Nut M5 (10pcs)
#Z663 - Lock Nut M3 (6pcs)
#Z664 - Lock Nut M4 (4pcs)
#Z665 - Lock Nut M5 (4pcs)
#Z682 - Flanged Lock Nut M5
#Z684 - Flanged Lock Nut M4 (4pcs)
#Z700 - Set Screw M3x3mm (6pcs)
#Z721 - Set Screw M4x4mm (4pcs)
#Z726 - Set Screw M4x12mm (6pcs)
#Z747 - Set Screw M6x45mm (4pcs)
#Z823 - Washer 4x8x1.2mm (12pcs)
HPI Baja Body and Body Accessories
#110678 - Baja 5b-1 Buggy Painted Body
#110679 - Baja 5b-1 Buggy Painted Body
#85452 - Wing Set (Black/Baja 5b)
HPI Baja Wheels and Tires
#110545 - Wheel Bead Lock Rings
#3221 - Super Star Wheel Black
#3226 - Super Star Wheel Black
#3241 - Wheel Bead Lock Rings
#3270 - Heavy Duty Wheel Bead Lock Rings
#3271 - Heavy Duty Wheel Bead Lock Rings
#4737 - Dirt Buster Block Tire S
#4812 - Molded Inner Foam Ms
#4831 - Dirt Buster Rib Tire M Compound
#4834 - Dirt Buster Block Tire S
Oils and Chemicals
#Z141 - Baja Shock Oil 5w (100cc)
#Z147 - Baja Shock Oil 40w (100cc)
#Z159 - Thread Lock
#Z168 - Heavy Duty Grease (10g)
#Z181 - Silicone Diff Oil #1000 60cc
#Z186 - Pro Thread Lock (Red/3cc)
#Z190 - Air Filter Oil (30cc)
#Z191 - 2 Cycle Oil (100cc)
Fuel and Fuel Accessories
#87467 - Fuel Line (Black/50cm)
#87468 - Fuel Line (Yellow/50cm)
HPI Baja Tools
#85459 - Ball Press Tool 14mm
#Z901 - Allen Wrench 1.5mm
#Z903 - Allen Wrench 2.5mm
#Z904 - Allen Wrench 2.0mm
#Z908 - T Allen Wrench 4.0mm
#Z909 - T Allen Wrench 3.0mm
#Z950 - Cross Wrench (Small)
#Z956 - Wheel Wrench (24mm)
#Z957 - Multi Tool
#Z970 - Bearing Press Tool 12x24mm
HPI Baja Videos
Getting Started
HPI Baja "Home Videos"
For sure , I found that the manual I got with my five year old box , was completely useless, but that's like everything else that came in the box , except for the engine and a couple other parts , I've been reading on these things , don't know if it all right or not , but seems these things have not been made for 5 years !? , And all the rollers were bought up by people who knew what came in the box , I'm told this how it went down 😵‍💫😵‍💫🤔🤔🤓🤓
Status
