Fijon 1/5th scale motorcycle
Julz
New Member
Hi.
Anybody own's this bike nothing says in the manual to add some shock oil in the steering damper and the rear shock should I add some oil if so what type of oil need more info Thanks
Ok guys did a bit of digging, turns out this is a knock off dean tech 913 motorcycle. Good news it they use silicon oil in the shocks.(dean tech) Bad news I couldn't come up with a specific weight. Apparently the manual isnt available online (that I could find) and to boot there is limited info out there about either manufacturer. It seems dean tech is out of business, and the fijon websight leaves something to be desired, as it doesn't have a section for manuals and what not. However there is a contact section. Send them a message and see what they have to tell you. Best of luck.
http://www.fijon-rc.com/index.aspx?lanmuid=86&sublanmuid=708
Product page link for the one who want to see it
http://www.fijon-rc.com/index.aspx?lanmuid=82&sublanmuid=730&id=49
I just emailed a buddy who has a 1/5 motorcycle. He said he's tried everything from 3k to 8k shock oil in the back and that 7k is his preference.
