Greatly appreciated! Thays exactly what i was looking for.Hello,
for the middle wheelbase you will only get the Porsche, BMW M3 or Mini Cooper body shell, for the long wb 530 you will get much more body shells.
By the 510 wb you will have a bit different front axle the lower arm and the steering arm is different to the long wb. The rest of the car is the same (chassis and belt/tunnel is longer).
Hello Roger,Can i use front/rear drive axels and front/rear aluminium arms from a 510 baja competion on a baja 535?
