f1 ferrari sportsline build
renbar
kirby cross essex
this aint my car which is a shame lol,, its a fg sportsline with some tasty upgrades front upper and lower alloy arms which are black anodised alloy front hubs and a samba pipe cables all round its got a 23cc cy fitted at mo which ive fitted a wt771 carb to other than that its stock for now
and within a hour or two of my mate dropping the car off
ditched the stock plastic diff and fitted a full alloy adjustable which can be adjusted via a small hole in the belt pully
most important upgrade switchblade kill switch I soldered this in
and its got to have a Ferrari red engine
and some stickers as the fg ones are hard to get ebay sorted that
more to come soon
al im think its msc as well mate from @98-99 his helmet colours changed I think when rubens joined Ferrari as he had a similar design helmet to schumachers with the blue top
any way f1 Ferrari's nearly ready to roll again steering servo turned up today that's in and working ive set the endpoints so it cant hit the alloy wishbones need to set it up next
ok time to step things up a bit
first mod was a rare old billet cnc engine mount/quick release bracket in red this was a ebay sniped part and a unreal price under £4 posted and it was brand new
this needed some work for me to get it fitting right and straight,plus I had to drill centre of the quick release part clutch side im thinking this part was meant for the solo line of engines
that's the first upgrade/mod all done,, more to come
here we go the best mod that's just perfect for this Ferrari f1 build possibly the best 23cc Zenoah money can buy who would like to see what 7+hp 22500+rpm and a true 23cc thanks to a very special crank shaft 28.6mm stroke giving this mighty little zen 7.2hp 4.2nm plus the best bit made in Italy
first pic looks no different to any Zenoah
next clue lol
ok here goes
Zenoah modellsport 230 m1
modellsport m1 alloy manifold with m1 modded wt990 carb
heres another ebay find we got these cheap 2 rn tuning air filters brand new £20 posted
that's all for now as you can imagine the owners probably skint after that lot,, more to come soon
time for some more updates first up new diff a oddie harm mag diff this was a real pain to fit due to the f1 running belts as the outside dia of diff was larger than inside of rear diff pulley so the dremel sorted that
ive also been playing with carbon fibre on the boat and just had to skin the f1's filter
have also fitted a oddified mk2 ecu
new rear spoiler scsm2 waiting on the carbon fibre blades as wrong ones were sent
this next mod is a bit more involved and big respect to the owner for letting me do this as there was no turning back but the mod just makes sense and looks like it should have came that way
this involved cutting the side supports moving the brake and throttle servos and fitting 2 standard servos for steering lowering the whole lot down and making it a fair bit neater I used a 3mm sheet of carbon/grp made a custom servo tray I have a little more work to do but I think it looks great
thinking of making new sides from carbon I need to move hydro master cylinder to try and get linkage a bit straighter will be spending a bit of time with wiring as its got to be tidy need to sort a switch but its getting there
no mate closest to kers we can do al is kerbs lol we have thought about drs though but I would like to see a old skool 70's-80's bodyshell made for it
day 2 on the radio tray build nearly done just need to wire in switch and voltage gauge then set all the end points and linkages
went with the carbon sides looks real good car feels as stiff if not stiffer I managed to fit brake master cylinder where I wanted it so it lines up nice with servo cant wait to try it
Nice work renbar, looking good.
Thanks for posting the photo's........
Your making me want to work on my F1. I need to though because of an upcoming event.
Keep us posted. Interesting stuff!
Regards
BM
nice day bashing today with the fg's f1 now wearing some new grp a wheels/tyres massive difference in grip
plus the new front spoiler from lightscale
Hi,
That looks great!
Nice job on the carbon mod, what thickness carbon did you use and where did you get it from???
I'm looking to buy a FG F1 and hope on doing this mod also
Thanks
You have some serious know how Renbar, very cool. I noticed you put the tps kit in this car too. I guess it's worth the $300? What kinda performance gains do you get with that kit? I've read it helps cool the motor better, do you run cooler now or just better performance?
