For Sale EmeryworX RR10 Bomber Chassis #001 of 001
cmbscx10
LSF Plus Member
PLUS member
Ramona, CA
I had commissioned this chassis to be built in March 2016 by a company called EmeryworX Fabrication. He went by tuner on RCCrawler and if still in business probably on Fakebook. I started the build with a no expense spared attitude, but life changes made me get out of the hobby shortly thereafter and it was 85-90% completed.
The only things left to do were finalizing the wiring and final assembly. Due to the nature of the hobby and probably a 1 off build, there has to be an understanding that minor fab work and custom touches would need to be done to complete. When it is complete it will truly be a killer RC even after almost 8 years later and one of the reasons, I never sold it.
I will answer any and all questions I can but keep in mind my RC knowledge is up to 2016 so it may take me some time to answer while I research and go back to my notes and through memory. I took photos during the build so I have many, many, many more I can send to interested parties.
$3,500 Local Pickup in Ramona, CA 92065
$3,650 Shipped from Ramona, CA 92065
PayPal accepted and Local pickup preferred
If my price is off be an adult and let me know why
Trades:
Just about anything RC related. PM me.
I am sure i will need a new motor for my Vekta .5 TT after i run it a few times in stock form.
Vehicle Build Specs:
EmeryworX RR10 Bomber Chassis #001 ** Probably the only one he made **
BarnDog Body Panels
Electronics:
Mamba Max Pro
BEC - Castle Creations; 10-Amp @7.4v
Tekin ROC412 2300KV
Hitec HS-8380TH Servo (.14 sec/60 - 486 oz-in @7.4v)
Robitronic Aluminum Horn; 23T
Custom Servo Plate (Custom made by cmbscx10)
RCBros Servo Mounts
Holmes Hobbies Receiver Bypass
Receiver - Spektrum SR3100
Drive Train-Front Axle:
Axial AR60 Axle
Beef Tubes Steel
GripFab SS Spool
Axial Heavy Duty Bevel Gear Set 38T/13T
Vanquish Wraith VVD V1-HD 5mm Stubs
Vanquish Wraith Scale Chubs 8deg Silver
Vanquish Wraith Scale Knuckles 8deg Silver
Vanquish Knuckle Bushings
HR Shock/Link Mounts; Black
SSD Titanium Steering Links for Wraith
MIP X-Duty C-Drive Spline Center CVD MP08136 w/ SS Exclusive X-Duty MIP Male Bone; Front
MIP X-Duty C-Drive Spline Center CVD MP08136 w/ MIP Male Bone Spline MP9169; Rear
MIP 6mm Bore Spline CVD Hub
Diff Cover - RC4WD ARB Orange
Black-n-Tacky
Drive Train-Rear Axle:
SSD Diamond Centered Axle for Wraith; Grey
SSD Skid for Diamond Axle
Vanquish Shock/Link Mounts; Red (Will D-Ano on 1st teardown)
GripFab ARB Locker
Axial Heavy Duty Bevel Gear Set 43T/13T
Lucas Red-n-Tacky
Transmission Super Shafty Bullet Proof Trans Clone (built by cmbscx10):
Skid Plate - Axial; Stock RR10 Bomber
DMG Adapter Plate
VP AX10 Housing
VP Motor Plate & Gear Cover
HR Metal gears
SuperShafty 6mm Extended Outputs F/R
SuperShafty Top Shaft
Robinson HD Slipper
FE bearings
Pinion Gear - Robinson Racing 12T/32P
Spur Gear - Robinson 56T/32P
Lucas Red-n-Tacky
Suspension Links:
Upper Front Links - Vanquish Titanium; Wraith
Lower Front Links - Vanquish Titanium; Wraith
Upper Rear Link - Incision Yeti 1/4" Stainless Steel w/Revo Link Ends
Dlux UCfab RR10 Bomber Trailing Arms w/Revo Link Ends
Suspension:
Vanquish Currie Antirock Yeti Sway Bar
Traxxas Big Bore Shock (XX-Long) TRA2662 (103mm E2E); Front
Traxxas Big Bore Shock (XX-Long) TRA2662 (103mm E2E); Rear
RC4WD King Dual Spring Shock; (120mm); Rear Springless
Shock Spring - Axial 14x70mm 1.43 lbs/in - Purple (Blue Springs); Front
Shock Spring - Axial 14x70mm - 3.29 lbs/in - Yellow (Blue Springs); Rear
Shock Fluid - Traxxas; 30w; Front
Shock Fluid - Traxxas; 30w; Rear
Shock Fluid - Factory Team; 40w; Rear Springless (120mm)
KBess Mfg Wraith Blue Limiting Straps; Front
KBess Mfg Yeti Orange Limiting Straps; Rear
Wheels/Tires:
Locked Up RC Gear Jammer 2.2 SLW, Snowman Rings, 4-40 Scale Acorn Wheel Studs, Scale Zinc HW; Front/Rear
VP SLW Hex Hubs - .475; Front/Rear
Hex - Axial 12mm Aluminum
Hex Pins - Axial
Pit Bull RB2's; Front/Rear
Foams - Crawler Innovations DDeuce 6.0” Comp Cut Inner /Med Outer; Front/Rear
Lighting:
MEMA Engineering Alien Light Bar - 800 Lumens Alien Light Bar **
Vanquish Products Rigid Industries 1" LED Light Bar Silver; Front
RC4WD Baja Designs Squadron Pro LED Lights; Front
Axial AX80103 Rear Light Bezel; Rear
Axial AX80049 LED Lens Set Yellow/Clear; Rear
HeyOK KOH and Brake Light Controller w/LED's; Rear
** I have no way to measure but that is the claim
Scale Accessories:
RC4WD Aluminum Fuel Cell
RC4WD 1/10 Hi-Lift Jack
Screwdriver (Custom made by cmbscx10)
CB Antenna (Custom made by cmbscx10)
ABC Fire Extinguisher (Rattlesnake Toys)
Axial RR10 Bomber Interior
LED Voltmeter/Speedometer ** Credit to WesleyRoy for idea
Credits:
Credit to those who inspired my build ** Don't get butt hurt if your name is not on the list. Credit goes to many and i thank everyone for making me feel like i did when i received my Tamiya Frog at 6yo.
  • tuner (EmeryworX) for building me such an awesome chassis
  • bilinvic
  • 2-shot
  • mjderstine (Super Shafty)
  • Krazykrawler
  • Screamer
EmeryworX RR10 Bomber Pics
