Maybe order a TR, Bonehead or Taylor RC one and avoid this altogether. Just a thought.Not sure it all happened so fast within minutes after start up ran up and down twice. Just order another one from rovan
Got to red loctite them little grub screwsI think maybe the set screws that hold the break pins in weren’t tight not sure if I remember loctiting them.
Will do I’m not missing any screwsAnswered my question Swap a wheel and that will tell you which it is
I Put the front wheel in the rear and you can see nothing is bent . But the wheel I moved to front is wobbly still it’s eather it’s rim or plastic warpedAnswered my question Swap a wheel and that will tell you which it is
Are the 3D ones a lot thicker ? Seems like the light weight centers aren’t bad with a small bore if you tumble but might not be strong enough to handle a big bore flip. I can’t imagine if I ever flip the vekta all 4 wheels would be wobbly.Yeah I damage the inner part of my hex gen wheels when I snapped my irc drive so I can see the light weight ones bending easily
