Ferrebee88
Kraken Vekta.5 with ESP 34cc engine and full Vertigo transmission.
With stock tires I am currently running the 19t/22t configuration. I am installing the Maxxis Trepadore tires and need to lower my gearing to match the larger size tires. I am assuming using the 17t as the pinion and the 24r as the intermediate is the lowest gearing I can achieve with the Vertigo gears? I am hoping this is a good place to start and isn't too low.
I am assuming 17p/24 is the lowest, 24t/17 is the highest, and the 19/22 and the 18/23 are in_between?
