yes mate, every one i've had or built up always has a couple of mm or so in and out play ,Hello guys good morning
Is the lay shaft in the Baja transmission supposed to have a little in and out play?
Ok yes it’s only a few mm of movement.yes mate, every one i've had or built up always has a couple of mm or so in and out play ,
if its 5mm or more then sommats amiss though
as long as you made sure you had the pin and the daft little retaining clip for the gear on the inner side of the layshaft plus both bearings in the top of the tranny for the shaft to run on then all should be tickity boo mateOk yes it’s only a few mm of movement.
Thank you very much I appreciate it.
Thank you DougOnce its all buttoned up the play goes away
